Create a new entry in the MIB view table. The default Layer 2 MIB view cannot modify SNMP settings. However, a new MIB view created with Layer 2 permission can modify SNMP settings.
Switch:1>enable Switch:1#configure terminal
Create MIB views:
Switch:1(config)snmp-server view 2 1.3.8.7.1.4
The following table defines parameters for the snmp-server view command.
Variable |
Value |
The first WORD<1-32> |
Specifies the prefix that defines the set of MIB objects accessible by this SNMP entity. The range is 1–32 characters. |
The second WORD<1-32> |
Specifies a new entry with this group name. The range is 1–32 characters. |
